Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: SAS swap / 01 DC Tacoma
  1. #1
    Senior Member TKGN1's Avatar
    Join Date
    Jun 2010
    Location
    College Station TX
    Posts
    414
    Moving along on the rear suspension. Been working on it a few hours at night (wife and kids out of town).
    After cutting all the stock suspension stuff off I set up the hangers nice and square (spent a little extra time insuring that), boxed the frame in, and added my own crossmember/spare tire carrier. I can fit a 33" tire underneath, but most likely will just leave the stock spare. The rear most rusty tube is a temp brace I put in to keep the frame from spreading.
  2. #2
    B4 u say anything, prepare to STFU Mauzer's Avatar
    Join Date
    Aug 2010
    Location
    Republic of TX
    Posts
    857
    I don't understand? Why would you want to keep the stock size spare? Trailer tire?
    "If we ever forget that we are One Nation Under God, then we will be a nation gone under."
    -Ronald Reagan
  3. #3
    Lesbian trapped in man's body TacoXpo's Avatar
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    2,299
    Lookin' good!
  4. #4
    Known to eat paint chips Silverback's Avatar
    Join Date
    Jun 2010
    Location
    America.. fuck yeah!!
    Posts
    5,919
    x2 on the stock sized tire. Not seeing the point.
    The rest looks great though.
    I'm not happy until you're not happy.
  5. #5
    Join Date
    Jun 2010
    Location
    College Station TX
    Posts
    414
    Quote Originally Posted by Mauzer View Post
    Quote Originally Posted by Silverback View Post
    Well, a 35" will not fit in the stock location (33" tire should fit). I want to maintain the stock location for daily driving/hunting use, I don't want to clutter my bed with a spare tire. If I wheel at a location that I need my full size spare I'll just throw it on the bed and strap it down (have one just very rarely use it).
    Figured if I'm not wheeling a smaller spare will suffice to get me back home/out of a bind. With selectable lockers front and rear it won't effect the drive train running different size tires for a bit, look goofy yes, but I won't be stranded.
  6. #6
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    2,299
    Quote Originally Posted by TKGN1 View Post
    I have done the same with the stock spare before when space was at a premium. Also, I have just run the small one up front figuring I would put less wear on the differential. Another reason for the expensive solution to have selectable hubs in the rear!
  7. #7
    Join Date
    Jun 2010
    Location
    College Station TX
    Posts
    414
    Got the rear diff prepped for install. Plasma and grinder took care of business.
    Set the rear under the truck, centered axle, set pinion angle and tacked the perches and shock tabs in place. I pre-loaded the suspension with ratchet straps to get everything set right at normal ride height before tacking in place.
    Still need to get the upper cross tube for the shock mount put on and get the tabs for the brake lines/e-brake cable put back on.
    After that it is a little paint and start assembling everything back on the truck.
    Hopefully will complete it ALL this weekend. I am so ready to get this part of the build done.
  8. #8
    Administrator drew02a's Avatar
    Join Date
    Nov 2013
    Location
    San Antonio, TX
    Posts
    6,369
    Why new spring perches?
    TacomaOffroad.com | 4RunnerOffroad.com
    There's a term for people without beards... "women"
  9. #9
    Join Date
    Jun 2010
    Location
    College Station TX
    Posts
    414
    Quote Originally Posted by drew02a View Post
    New perches are longer, already have three holes for moving axle back or forward, and allows the axle to be rotated for better pinion angle.
    I started to leave the stockers in place but figured I have everything torn apart so why not do it at this point.
  10. #10
    Join Date
    Nov 2013
    Location
    San Antonio, TX
    Posts
    6,369
    makes sense
Posting Permissions
  • You may not post replies
  • You may not edit your posts
