Got back on the Taco finally. Got the GMRS antenna finally ran into the cab and all buttoned up... it works. Pulled the group 31 battery out from the rear (she was just about dead) and used it as a core when I got a new front battery. Replaced group 65 up front with a group 27 X2 Power AGM. I'll use the old group 65 in the shed to power some led lights... it should work for the brief time I will use them. Pulled the Noco 4 amp shore power charger all out to be replaced with a 5 or 10 amp version (have both.. whatever one does not go here will go in the trailer.. 5 fits better but 10 would be mo'betta). When I pulled the Noco out I noticed that little bed side cubbie box had a lot of holes in it... like 9 extra from all the other bullshit that has lived in their prior. So I ordered a new side box (BTW, they are not cheap at close to $100). So the new Noco install is on hold until I get the new side cubbie. Project for tomorrow is to pull the old airlines that go from the air tank below and into the tool box. I won't need them as the compressor is now in the side of the bed. Also that needs to be completed. Air lines need to be ran and wiring needs to be ran. I also got a new head unit. New Alpine with carplay (so I can use Gaia and Google maps). It's nothing special, I wanted sorta simple. As long as it had a good screen, carplay, 4volt pre-outs and a good S/N ratio I was good. Oh and steering wheel controls.
I hope to install that this weekend. My goal is one thing a night, even if its something small. Eating an elephant here.
