2001 4Runner build/fix log
Finally have some armor to install so I figured I will start a build thread. I purchased a 2001 4Runner that came with a ToyTec lift and supercharger already. Now I just have to get the maintenance caught up and some armor/gears in it for the trails.
As it sits currently...
Current setup:
Motor and Trans:
3.4 V6 w/ supercharger
Airaid Intake tube for ISR mod
Automatic transmission w/ B&M 70266
Transgo Shift Kit at truck setting
Wheels and Suspension:
265/75-16 Hankook DynaPro AT-M
16" TRD beadlocks in black
ToyTec 3" Ultimate lift (set at 2.5" currently)
Camburg UCAs with uniballs
Rokmen rear trailing arms
Driveline:
Traction control disable switch (aka Andy Mod)
Toyota e-locker with 4.30 gears
Low Range OffRoad elocker harness for locker control
Front/ Rear diff breather relocated higher up body
Armor:
Lotus Rear Control Arm Mount Skids
Schrockworks sliders
RCI Aluminum skid
Lighting:
18w LED flood light pods for backup lights mounted into rear bumper
25" LED light bar mounted flush into grill
Other accessories and stuff:
Rack built March 2017
CVT Mt Shasta Extended w/ Annex
Midland CB mounted in dash (old ash tray spot)
General stats when I bought it home :
Automatic transmission w/ Hayden cooler
265x75-16 BFGoodrich All-Terrain T/A KO2
16" rims off a Landcruiser LX450
Trips
Big Bend Ranch State Park - Dec 2015
Highwater Trail in Arkansas - Oct 2017
Big Bend Ranch State Park - Dec 2017
Plus other smaller weekend trips mixed in.
Build Updated 1/7/2018
Added TRD Supercharger install manual for reference
  • TRD34LSCInstal.pdf
The first full weekend I had the 4Runner I swapped out the Hayden trans cooler for a B&M 70268 cooler. I also relocated it up above the bumper behind the grill for better air flow. After a couple weeks of driving around with this setup I ordered a thermostat to bypass the radiator and yet still maintain at least 160 degrees for proper trans functions. Also going to upgrade to a larger B&M cooler at this time - the 70266 which is rated for cooling 7k more BTU than the 70268. Also picked up a new radiator to replace the current radiator when I get a chance.
Received Lotus Rear Control Arm Mount Skids today. Hitting them with a few coats of paint before I mount them. I am going off of Sam's good advice to protect the rear control arms before I beat them up. Will update with some pics soon as I get them mounted.
Great start
It's been awhile since anyone started a new build thread :)
Yeah; hopefully this one gets a little further down the line than my last one. Tomorrow the brown truck should be delivering more boxes for maintenance and "repairs" this weekend. I need to replace the rear bearings on the S/C and "repair" the intake tube with an AirRaid tube.
Sweet! Elock in rear?
Maybe; still seeing what is available and budgeted for when I get there.
*no rear locker at this time but it is quickly moving up the list.
Today's new battery was expected - just not this soon. While the old battery was charging up enough for me to start the 4Runner I went ahead and installed the AirRaid intake tube. I was skeptical but won over by the actual dyno results and places where the guys with superchargers were posting positive reviews of good low end power off idle. I will agree; the 4Runner moves off idle real easy now.
First - AirRaid installed. It really is about a 10 minute install if you read the directions.
Second - finally had enough time for the Lotus LCAMS to dry properly. Here is a before/after pic. They really are a stout piece of hardware. Thanks for pointing me towards these, Sam.
Third and final - making use of the "tool box" area. Probably going to pick up a few more things to store in there; but for now this is it. I keep the jumper cables with the factory jack (not sure why I keep the factory jack on the 4Runner; it has no chance of working now).
Slowly but surely I will bring this thing along. Next up on the list is to replace the battery cables; these are grungy and getting brittle. Plus the previous owner used a red cable for the ground cable to the fender. :facepalm:
SamSter0077
Frack me..
you should probably run some good 14guage or better cables to the back (to power you future ARB beer fridge) while you are replacing crummy wiring..
and remove those damn running boards! :p
The ARB fridge is tempting - so I have cold water while I am driving from office to office during the day. As for the running boards - their days are numbered. Hopefully Christmas will be good to me.
Looking good man. Its getting there. If you do get an ARB fridge, and I highly recommend one, add a dedicated plug in the back with the ARB fridge plug portion hardwired into the vehicle, not using a 12v outlet. The ARB 12v outlet plugs SUCK! I've broken 2 of them. Fragile things. I just cut the plug end off and hard wired it to a fuse block. I actually have a weatherpack connector under the seat so technically I can pull the cord and move to another vehicle if it had the same weatherpack plug. But the fridge has been in the backseat of the Taco running 24/7 since Memorial day. Its great at work because I can keep beverages cold as well as lunch (obviously) but I can also run out to the grocery store at lunch and pick up steaks for dinner or whatever and then just throw it in the fridge.
I see that red 4ga wire going to the firewall... yeah PO was an idiot.
As for a jack, go pickup a 6-8 ton bottle jack from Northern Tool. I have one and the damn thing fits in the factory position and it goes up to like 18" or something.
Thanks for the tips on the ARB and jack.
I have been reading on how to use a Firestik antenna for both CB and AM/FM use. I would like to mount it in the factory antenna position. Any experience or thoughts? Yes - Firestik does make a 2-into-1 adapter to run both devices over the same antenna. They express that the user must use a high quality antenna and that tuning the CB without the splitter first is important. I want to install a small CB where the ash tray is at so as to have it there full time. Less gear to haul in/out for trail purposes.
Current plan is to get the splitter, run the cable to the mount, then have a Firestik HD spring for some flex, and then a 2' Firestik antenna for DD use. I will decide after use if I want to pick up a 4' Firestick to tune for expo use where better range might be an advantage. So - anyone done or seen this setup before?
  • Like
Reactions: tex
Never seen it done but I would use a Firefly... its a flexible Firestik.
Would that remove the need for the spring? Then I would be able to just use a quick detach base for when I want to take it through the car wash (all three times a year).
Yep. Its what I have on the Taco. Flexes as I come through the garage door.
Ham :)
werd
At 199k miles the supercharger got it's first rebuild. I had it on the bench pretty easy; but quickly realized the bearings were not going to cooperate with my lack of a press and bearing puller. I took the case to a local performance shop and let them deal with it. They spent most of the afternoon and some time in the morning getting the old bearings out and the new ones in. I will give them credit that they handled it like any of their other performance vehicles. The owner used a lathe to machine a punch that would hold the bearing straight and seat it perfectly.
I cleaned up the parts that move, lubed the parts that touch, and removed the extra material from the intake manifold gasket to allow for the proper amount of air flow. A couple pics from the event - not looking forward to doing it again in 100k.
Stock intake gasket before the dremel tool compared to the actual intake port.
And how they matched up after the dremel tool adjustment.
Looks like I will not be wrenching next weekend. I'll enjoy the break. Also made the first payment today. lol
Originally I was planning to mount a CB antenna in the stock radio antenna location; but research that found reports of splitting/busting fenders due to the increased weight/wind resistance has changed that plan. I am thinking now I will get the CBI ditch light brackets and mount the passenger side bracket for the CB antenna for now. Then when I get the front bumper I will move it down to the bumper. After I move the antenna I may or may not use the brackets for ditch lights - will decide at that time. If I add a second antenna on the back of the 4R will depend on if the front one is not getting the coverage I am looking for.
The original plan of using the one antenna for the radio and CB is still a solid plan as long as I use a quality splitter and CB antenna. That part of the plan has not changed and I am hoping to have it working before Big Bend.
  • Like
Reactions: tex
