I prefer astro glide FWIW
What kind of grease do you use Boyd?
KY fire/ice
ssssssshhhhhhhhhhhh
ewwwwww.... visual of a greased up Boyd/Keith/Lurry tripod...
Ok, I temp fixxed my LBJ's..............bought a needle fitting thingamajig and pumped those bastards full of grease. hopefully it will last. Also got tie rod ends, need to get those installed ASAP, got a ton of slop on the passenger side.
I prefer the homebrew!!!!
Mix it in a plastic bag. Cut a hole in the end. Squeeze 'er out!!! It looked like you already squeezed one out!
Thanks for the write up, been needing to this for a while now, just haven't had time to do it yet, made it look fairly simple to do
It started with the technical peeps at Total Chaos. They were recommending a graphite synthetic. My experience with this mix is 100% quiet - now if I could have some way to encapsulate the uniballs with this mix - or I had thought of just dry graphite - I would be squeak free without having to spay or squirt lube on them!
It's not, but we can handle it
