Which part are you thinking might be a tooth or two off?
I'm not sure what's a lot of movement but when you hit the gas but I would say the pinion angle moves a lot.
No idea. I will be taking the car to Drive Shaft King in Dallas tomorrow morning to get the stock shaft modified with a double cardan input joint behind the carrier bearing. They said they could do the work and Tom Woods said they would take the single piece shaft back and issue a full refund. We shall see what happens.I wonder what he did to break it.
Likely had to use a small joint, like a 1310 or something like that. If I were to build a two piece cv driveshaft I would either run a 1350 cv or an OEM toyota cv. Mitigating axle wrap is the bane of leaf sprung vehiclesI wonder what he did to break it.
He said, "Failure occurred at the midship stub. To convert it over, they have to use a smaller diameter and therefore it's substantially weaker. Here's the snapped off midship stub inside the stock factory yoke for size comparison. Broke on the side of a moderate difficulty trail. Nothing that should warrant a failure."Likely had to use a small joint, like a 1310 or something like that. If I were to build a two piece cv driveshaft I would either run a 1350 cv or an OEM toyota cv. Mitigating axle wrap is the bane of leaf sprung vehicles
Right?!?! My thoughts exactly. I think it may have been a freak thing but I'm not 100% convinced either way. So weird.Damn never seen that before, I would expect to grenade the cv or the tube before breaking the stub like that
