1. Carefully use a wooden screw (very coarse thread) to screw into and literally pull out oil seals...ie rear main/ front main.
Along the same line, for cam and crank seals I like to drill a small 3/32" hole in the metal ring of the oil seal and by hand screw in a short sheet metal screw just 1 or 2 turns. Then you can use a flat head screw driver and pry under the head of the screw to remove the seal.
