Splinter or metal shaving into finger or skin??
A couple drops of Elmers glue and 15min later peel glue off and out comes the splinter.
I'm not sure this is Marine safe. We always ate the glue.
(2) Barbed fittings - http://www.amazon.com/Anderson-Meta...&redirect=true&ref_=oh_aui_detailpage_o02_s00
(1) Valve - http://www.amazon.com/Smith-Cooper-...&redirect=true&ref_=oh_aui_detailpage_o02_s00
(1) Pump up Sprayer - http://www.amazon.com/Chapin-20000-...psc=1&redirect=true&ref_=od_aui_detailpages00
You'll need some 1/4" ID clear tubing as well.
Used for Diff or Xfer case refill
As long as the fluids are cleaned out you can probably use it for any fluid fill you want to do. That makes working under the truck a good bit easier now.
HiLift is what I use.HiLift jack works super simple as well.
I run the same shit in both anyhow.
How did you save it? I need to do that as well.I have that entire directory structure saved on my tablet so I can access it from anywhere.
LOL!
As for digging metal splinters out in usually mangling my finger with a super sharp pair of tweezers to dig it out. I'll try that next time.
