So Mario does a little preventative maintenance and changes his water pump and radiator... couple of days later blows a head gasket. So I was just seeing if there is a cure and found this. Cu head gaskets make a lot of sense but would love to confirm that its a good cure. I used to reuse Cu head gaskets all the time on two stroke bikes by heating them up 'til they were red hot and letting them cool slowly (annealing them).
He's feeling a bit
right now!
These folks can make any gasket you need from copper and at many different thicknesses: http://www.headgasket.com/
I solved my 3.0 headgasket problem FOR GOOD with a solid copper gasket from these folks.
I spent a weekend at work modeling this concept on an engineering thermal analysis tool before concluding that the copper gasket was the solution to the problem. Good idea to use head studs vs bolts, delete the rear cross over exhaust, replace the clutch fan with a flex fan and install a new radiator as well.
I derive no benefits from promoting their products.
He's feeling a bit
