CalgaryRider
SR5 with a TRD Sport heart
So here is the issue that I am struggling with, and I cant seem to figure out what is the underlying cause.
The issue is that my brakes are really soft on the first press of the petal. But if I release and then press down again, they are firm.
I'm thinking this can be 1 of 3 things.
1. The TSB on the brake petal may be causing the issue and I need to have it done.
2. Now that I am lifted the brake lines are not long enough and they are being stretched and not allowing enough fluid through.
3. My brake master cylinder is dying and not pumping enough fluid into the system (I check the fluid levels last night and I was good)
Any suggestions or recommendations would be greatly recommended, cause I am stumped! If its solution 1 or 3 then I will just go to the dealership, if its issue 2 I can just get new brake lines and solve the problem. Just need to know what the next step is.
Thanks!
Thanks!
