LSPV removal
This one, you will have to start here and trace it back. Hope this helps.
Rear shot
Here is the plug I made to cap off the T in the passenger side wheel well.
In the first pic you are looking at an "L" on the left and a "T" on the right. The return line is already removed in the pic, it is to the left side of the "T" on the right. I know that hardly makes since.
Sorry, I fixed it.
the plug is not installed in that pic, I can't find one with it but I can get one at lunch if you need it. Here is the plug I made, it is the old brake line fitting with a piece of welding rod welded inside of it and machined to a 45 deg. tapper.
