for everyone's knowledge the OEM part number for a 2003 2.4l 2RZ and 05+ Tacoma 4.0L MAF sensor are only one digit different...
Well I finally got to go test the 2rz turbo at Barnwell last weekend. Drove it around a bit. Motor hesitated at mid range rpm’s. When I was going 10-15mph the vss said I was doing 158 mph . I unplugged the pigtail and it was golden after that. I could actually push my 39s at speed in high range which I couldn’t do before. Low range was a beast as well. The manual controller made it possible to start in 1-4 gear easily. The truck is a different beast all together. Only problem was not tightening the rad mount to the core support. My fan ate the radiator on the last day. No biggie I guess. New radiator with a SPAL fan showed up Friday and I got it installed sat. Just need to finish up the fan relay wiring.
Twister with the 2RZ Turbo
youtube.com
