This fellow here might explain better than I can
The water pumps built for the 7 3 are weak, that's good you already took care of it.i replaced that when I first picked it up, so not too many. Maybe 4K or less miles plus the coolant filter is supposed to extend the life of the pump seals. The coolant on the bottom of the pump you may see on a few pictures is “normal” because it will leak out of the weep hole on startup.
