Boomtacoma's Buggy Build
Couple of update pics....
Probably going to be the nicest part of the whole buggy.. Carbon Fiber intake to the throttle body with the Turbosmart Vee Port Pro BOV. My buddy @SMKYTXN volunteered his time and a lot of effort/research to get this knocked out. I think it turned out RAD!
I'm going to add a rubber pad to the protect the carbon fiber on this chassis mount. Pass side Radiator hose is in. Driver side will need some work to the bottom side of the throttle body for the lower hose to clear.
Brake lines 3AN All 4 corners are done. Rear will have a pressure switch in line for the rear brake light.
Tried to F up this caliper in the process when the 3AN fitting twisted off. Thank God I got that pulled out and chased the threads with a 1/8npt tap. Hopefully it hold with the extra Teflon I put on the new fitting.
Chassis Tag from Adam. I added some heat and formed it on some 1.75 DOM. Still unsure where it will live on the chassis. Probably where it is right now. lol
Added a bump bar to the front. I tried to keep the tubes tied into the nodes as best as I could. The welds aren't as nice as Adam's but they should work. the bump bar is about 2/3 welded in currently. The winch can still be dropped in through the top. Not the best notches, but not to bad for my first try and I didn't have to start over. The Pipemaster helped out a ton!! Should help protect the winch and front lights when I get them tucked in there. I got the idea from the Wende Chassis owners page on FB. Suck down winch point also welded in place. Pretty nifty mount from Hulse Engineering and quick release pin from McMaster Carr. Keeping everything wiped down with the Fluid film has kept the rust at bay on the chassis.
Is the list getting shorter? LOL NOPE!!
  1. Fabricate aluminum oil pan In progress Thanks @SMKYTXN
  2. Buy Battery and mount Battery box - Done
  3. Layout fuel system components and plumb system- Done
  4. mount storage rack to lower support bar
  5. Measure and order Radiator hoses - Done, need to finish Driver side under throttle body.
  6. Drink beer in shop - Always!
  7. Weld out and mount Brake pedal
  8. Mount Accelerator Pedal
  9. Swap orbital mount, mount orbital, steering wheel -Done ish
  10. Lay out the Steering system components will be located under in the engine bay -in progress
  11. Plumb steering , rear steer, cooler, filter, resi, pump, steering cylinder hoses
  12. Work on front driveshaft midship mount- in progress
  13. Build front driveshaft - In progress
  14. Order parts for Rear Driveshaft
  15. Fab front bump bar- Done!
  16. Mock up Headlights
  17. Mock up Rock light locations
  18. Drink beer in shop - ONGOING
  19. tack in harness belt mounts- rears are in need to tack in the lap belt mounts
  20. Design Dog house - in progress Lay out components
  21. Layout IC7 display, Master power disconnect, shifter, usb charger on front panel.
  22. Weld out Doghouse
  23. Plumb Turbo to Throttle body - should be pretty sweet in Carbon fiber - Thanks @SMKYTXN
  24. Drink beer in shop -Check!
  25. in prog
  26. Floor pans/firewall/ expanded metal for diver and passenger side - in progress
  27. Figure out skid plate mounting for Transmission and engine
  28. Spend a lot more $$$ on parts -in progress
  29. Layout SwitchPros RCR12
  30. Layout power supply wiring from battery
  31. Finish brake rotor and caliper installation -Done
  32. Plumb brake system and brake light switch -In progress
  33. Need to swap the front 3rd to the rear and install the new 3rd in the front
  34. install TG axle seals (4) in both housings
  35. 05 up Direct Drive total spline 1550 outers from Branik, inner 40 spline shafts from ECGS/Branik--EEEKK $$!
Nathan's concept for my low pro Oil pan for the RZ to keep in in line with the Trans pan from the A340F. 4.5" deep with a little taper from front to rear.
Trap doors to keep the oil by the pickup
Looks awesome man.. that CF intake is sexy!!
