Morels very in price from $300 - $4000. The first set were in the $6-700 range. New ones are sold individually and designed so that you build your system that way. Just a much better speaker. They sound great... makes me want to replace the 8's I have in the doors now. :)
Ahh ok.
Time to update this thread I guess.
Lets see.. whats new.
New winch, Superwinch Talon 12.5. Relocated the solenoid and added synthetic line. Also added a 12 volt guy in cab winch controller.
I'll add another post..seems can't upload enough pics. :)
I also wired up a Blue Sea ML-ACR with manual control switch, this also included dual Noco battery monitor/charging ports in the dash. ML-ACR is mounted on a fabb'd up bracket that holds the SPOD and a large Kicker fuse for stereo.
Found time to get my Spod all wired up, complete with overhead OTRATTW switches. Build a new harness for it since the Spod switches only had 3 connectors and these had 4.
What else.. oh yeah got front and rear cameras hooked up that I can monitor at any time. Front is visible in above photo of winch.
Also got my Garmin rewired. All interior components got the rewire treatment actually... everything I added aftermarket was redone. All interior switched components are now powered by a 12 gang Blue Sea fuse block mounted under the front driver seat, on the very front lip of it so you can change fuses you just need to slide the seat back. I don't have any pics. Its bolted to a plate that is then bolted to the floor via a nut-sert.
Under the hood anything that requires switched power goes to a smaller Blue Sea fuse block I mounted on the core support up front. Again with nut-sert for ease of installation.
Added new lights, to include rock lights.
Finally one little item to confuse the libtards.
soonenough
Maybe one day...
This truck is awesome, great job on the wiring updates. That's one thing I would love to do is clean up all the wiring in my truck. It seems like anytime I add something, I'm doing it in a rush and I just throw it together quickly and ignore the mess that's already there. Would love to rip everything out and re-do it.
Story of my life as well...
Well I had planned to re-do it for years... finally pulled the trigger and just did it. Next will be the wiring in the rear tool box and make it presentable. What a mess!
Post these up in here so I can look back and know when I actually installed them.
Replaced UCA's for shiny new ones.
Now to just wash everything and make it all shiny.
LOL.. what shade tire shine should I use?
Ahhh puurrfect.
Mojave
New Member
Old thread I know. Really terrific build. I was wondering what the flashlight brackets were
for mounting the P17 flashlight. Thanks.
They are called Lite Lock, I bought them at Frys Electronics about 10 years ago.
So I determined that they are made by Nite Ize... but I don't think they are available any longer. Bummer. They do work well.
I have QF's in the truck and trailer. Not the same.
