The 86/96 Build
Ok. So strippers and coeds are out. I feel you have a backpack full of sugar free juice boxes and non sugar treats. Nobody giving a single moms kids sugar and expecting to get a good blow job. If she hears her kid bouncing off the walls she is liable to clamp down and leave scars. I pray for you my friend. God bless your quest for tight tasty pussy. I too was once on such a quest. It can be rewarding and adventurous. You will meet many that will challenge you and one that will fulfill you… or fuck.. probably a lot that will do that. But never forget your quest. Non crazy tasty pussy.
LOL!! We will see how it goes.
Instead of relocating the battery to the Driver side, I decided to mount ion the pass side like it was on the 2nd Gen originally. Extended the cables and modified the batt hold down bracket last night. Added an Ebay Hot air intake and got it plumbed.
To Do:
-hook up heater core hoses (fucking tight area) might say fuck it on that and plug em
-install TC shifter bushing
-weld front clip to the body
-finish installing dash
- seats
-install doors and hood
-swap rear diff
-mount radiator and overflow
-nut and bolt check front suspension
-check all the grounds
-check all fluids and oil
-add fresh gas
-leak check
-attempt to start and not burn down the garage SUCCESS!!
Been trying to get this shit knocked out. I'm also widening my car hauler 8" along with doing some maintenance on the Crawler.
Dash is 75% in. I need to attache the shifter linkage to the transmission. The center vent is proving to be a bitch. I need to get some coolant and fresh gas and see if it starts up.
Added some fresh fuel and 2 gallons of coolant. Need to double check a few more hoses then I’ll try to fire it up. I’ve been lacking on s.
And some pics of the car hauler mods.
New OEM grille and headlight buckets from Alex.
Doors on and wiped down. Not to bad for some almost 40 year old paint!!
Well this 3rz purrs like a kitten. Need to get the trailer out of the way, throw a seat in and take it for a spin around the block and see I don't run over any kids.
Did you have to do anything special to get the hood to clear the intake?
I had enough room to angle the intake down to clear the hood.
Cool.. I remember when Drew dropped a 3.4 in that 2nd gen 4Runner and he had to cut a hole in the hood to make it fit. Fuck that was a decade ago if not more.
Mauzer
Pitter Patter. Lets Get at Er
I think about that build often, it was the coolest 2nd gen I'd ever seen. Plus we use to go bomb the service road next to the train tracks by his old house to "test" the long travel, it was fuckin sweet.
Got a little more accomplished. Found a set of Mastercraft seats on FB marketplace which I was sure that was a scam. I was pleasantly surprised. I didn’t get shanked and got them for 300 for the pair. Got a set of inner door panels too. Getting real close now. Not everything matches but oh well….
Door panels look great!
