Putting in cabinets in the laundry room. Tired of looking at the junky metal shelf with everything exposed.
Before:
During:
I ran out of paint for the doors. I had a few leftover soft close hinges that aren't the right size. Plan to finish painting the doors when it is not raining and getting them installed. Will eventually get the proper sized soft close hinges, but the cheap ones they came with are fine for now.
In true builder quality fashion, the studs are not 16" apart. Each cabinet only has 1 stud behind it. They are attached at the frame face, so that adds some support. I'm contemplating putting a board across the bottom to help spread the load and give them somewhat of a shelf to sit on. However, for just holding laundry detergent type stuff, they are probably fine as is.
Next step is to move the washer over and add a sink. Have to redo the washer pan before I can move it though. Also need to get the trim edges for the sides and top so that they aren't just open.
Before:
During:
