Toyota Axle Ratio codes 97-2010 models
Don't feel like clicking the links with the droid what ratio does yours have ill look around see if I can find a replacement third for ya
I'll look on Yotatech for you.
LOL, I just PM'd you.. thanks Rob. 4.10 stock 3rd should be pretty easy to find. $637 for repair from the local shop. OUCH!
And thats with you pulling the third and supplying gears? 637 for labor is rape
IF thats including gears its 'reasonable'. That was with a 10 year warranty right.
SamSter0077
Frack me..
195 for the g2 ring & pinion (10yr warr..) 205 for the rebuild kit, two hours of labor (bench time) @ 90hr per.. tax etc..
Rape is right, ok Rob.. you need to learn how to do it yourself so we can just bring them to you. :D you have a Machine shop, should be a snap.. right? :D
Todd? side money, hello.. :D
I have too much crap to fix as it is.
You don't need the master rebuild, All you need is a pinion install kit, carrier bearings and ring gear bolts should both be reusable. And you should be able to pick up the gears for 100 or less used. Thats gonna immediately lop off 200 bucks, labor is labor but that install isn't very hard to do since you're keeping the same ratio pinion depth is already set just use the factory shim pack and you will be bang on with the pinion depth and setting the backlash is easy to do if you've got some marking compound.
they might require the master rebuild kit to give him the 10 year warranty.
10 Year Warranty!? Sign me up!!! That with AAA Premiere and you're golden!!! :) Now if that came with a trunk monkey that knew how to wrench!!! :D
Oh I thought you were joking about the 10 year warranty, yea I'd go ahead and go that route then in 10 years of wheeling it will surely break again at which point it has paid for it self.
SamSter0077
Frack me..
Scored a used third member 4.10 on T4R for $100.00.. Guy says it was recently rebuilt when he bought the runner. Need to put the Lockright in it and I am good to go!
Where is it located?
FYI, Not sure if you have plans to ship it, but if you take two 5 gallon buckets and cut a hole one of them the size of the pinion. Then screw the bucket with the hole inside the other bucket you can stand the 3rd member on its nose. Wrap it in some packing material and screw on the top. Its how ECGS ships em. Cheap and protects the 3rd.
Good one -I have even taken a regular bucket and formed the top using a heat gun. Works nicely and you even give the UPS man a nice handle!
Nice Find!!!
