Don't feel like clicking the links with the droid what ratio does yours have ill look around see if I can find a replacement third for ya
I'll look on Yotatech for you.
LOL, I just PM'd you.. thanks Rob. 4.10 stock 3rd should be pretty easy to find. $637 for repair from the local shop. OUCH!
IF thats including gears its 'reasonable'. That was with a 10 year warranty right.
Rape is right, ok Rob.. you need to learn how to do it yourself so we can just bring them to you.you have a Machine shop, should be a snap.. right?
195 for the g2 ring & pinion (10yr warr..) 205 for the rebuild kit, two hours of labor (bench time) @ 90hr per.. tax etc..
Todd? side money, hello..![]()
they might require the master rebuild kit to give him the 10 year warranty.
Where is it located?
FYI, Not sure if you have plans to ship it, but if you take two 5 gallon buckets and cut a hole one of them the size of the pinion. Then screw the bucket with the hole inside the other bucket you can stand the 3rd member on its nose. Wrap it in some packing material and screw on the top. Its how ECGS ships em. Cheap and protects the 3rd.
Scored a used third member 4.10 on T4R for $100.00.. Guy says it was recently rebuilt when he bought the runner. Need to put the Lockright in it and I am good to go!
