Damn I thought this got canceled for some reason. Glad it's still happening.
Replaced all 5 fans (2x140mm front intake fans, 2x140mm top exhaust fans, and 1x120mm rear exhaust fan) with BeQuiet Shadow Wings 2 fans today after work. Spent a bit working on the fan curves and will continue to fine tune as needed. Trying to keep positive pressure in the case at all but extreme situations to help keep dust intrusion down. Now I noticed my GPU is sagging ever so slightly so I'm considering picking up a vertical mount bracket before it becomes an issue down the road.My PC had both front fans failing. Was going to replace them but I didn't like the case anyway so this morning I transplanted everything ino a new case. This case doesn't have the PWM that my last caeh had so all the fans are running max speed and it's super loud (but still better than squeaky bearings and fan blades hitting the housings). So I'll buy some new fans and a separate controller for them so I can tune them better. Next year I'll upgrade mobo, CPU, and GPU with the newest gen.
Oh faithful. I've done all the main endings, but i like to change up how I play it now.I'm re-grinding Fallout4 to try a couple alternate endings
I may try a new game & use the leveling glitch to see what its like being OP from the time I leave Sanctuary
I did a full play through without ever going to Preston's annoying assI may try a new game & use the leveling glitch to see what its like being OP from the time I leave Sanctuary
Put about an hour into the new Assassin's Creed Shadows this morning. Of course the game mechanics are all new, just like every time they release one. PITA having to learn new shit each time, but so far it's pretty good.
