Mileage and date.. not part number. Unless the part number is 2018 June 1st ;) I did see someone, can't recall who, who used a paint pen and wrote part numbers for things like serpentine belt on his upper core support.
Whoops - I saw that but didn't comprehend what it was. I just keep the old belt in the new box in my tool box, but that's not a bad idea. I like your idea of downloading everything for the truck into a tablet and keeping it in the truck. Ill be digging around tonight trying to figure out what I need to do to get my engine out tomorrow using my beat up ol Haynes manual & a few other sources. One of my 4x4 buddy's is shaming me into the swap so he doesn't have to hit the trails solo. Called me last night and asked if we were still on. I said it's going to rain so if we wake up and it's raining we should call it. He called me a pussy and said I should set up my tarps and ez-ups then and he would be at my doorstep in the am. Nice to have a motivator from time to time.
Nice!! Will be great to see some progress done on it.
I like the mileage and part numbers in marker. I do the same to my oil filters, but need to start doing it to my air filters as well. I always forget to log that stuff on my PC.
I save all the part numbers etc on my phone and I usually buy them by the case/multiple for a greater discount.
Got my dual battery hooked up. Used a PAC brand isolater and 4 gauge wire to hook it all up. Also installed my new fridge and slide. This fridge is a beast. Cooled down from 95 to 35 in about 30 minutes. Ran it at 10 degrees for hours hooked up to the wall.
Voltage reading from 2nd battery while running.
Screen shot of the fridge app. Shows current temp, set temp, and voltage. I'm able to change temp and set a temp alarm from the app.
Nice! @tex
Having a compact and quality 3/8 air ratchet works wonders in tight places. Top bolt I had to use break over bar and 12pt socket to break loose.
Added a little bit of grease around clutch gear.
Sanded down positive and negative, added corrosion spray and dielectric grease into the terminal plug.
Completed.
Tex, Fridge setup looks great. How much they whack you for the slide?
Chased the B500. My idler bearing started crying soon after getting in to Mexico. At one part of the race, we had to go recover our car out of a ravine. Car jacked another guys' long travel taco to go recover the race truck. GLAD I did. My taco seized that bearing just after crossing the border. :) :D
Good reminder to carry a spare idler pulley.
Edit... speaking of. Do you by any chance have the part number?
Nice @tex... is that a dual zone fridge freezer?
I bought a whole drive kit.
GATES ACK070834 Accessory Belt Drive Kit
screen-shot-2018-06-04-at-5-43-16-pm-png.9988
Does your supercharged monster use the same belt as a NA rig?
Yep. The s/c has it's own belt. ...that will be changed to the ...Gates RPM (Racing Performance Muscle) version
Gotcha. I see that kit on Amazon.. will be ordering.. along with some upper and lower radiator hoses. 115k miles... I need to do those.
