Installed ECGS bushing, new axle seal and wheel bearing hub assembly on the driver side. Did a 100mi test drive to go pick up a new-to-me ARE camper top with Yakima rails.
Old axle seal removed and everything wiped down:
A couple of thoughts of things that I learned:
I actually did install the axle seal too deep on one side. Due to the angle, I couldn't really see it and I assumed it was going in flush. Since I had the grease on it, I was able to pry it back out some without damaging it. It isn't perfectly flush, but I'm hoping it's "good enough." I did a 100 mile round tip to pick up the camper top Saturday morning and no oil was leaked from what I can tell. Also, my driveway is clean.
1st and 2nd post updated
- Don't waste time trying to remove the hub bearing assembly from the axle with anything other than a hub puller. I learned this last time and it saved me this time. https://www.autozone.com/loan-a-too...ler/oem-front-wheel-drive-hub-puller/2050_0_0
- Don't be afraid to hit the axle with some force. A long flat head screw driver and 4lb engineering hammer did the trick for me.
- Getting the EGCS bearing removal tool between the spider gear and needle bearing was a royal pain. I could get it to start wedging in, but couldn't get it to drop in fully. After much deliberation and speaking with others who have done it, I decided to get it lined up as best as I could and then use the flathead screwdriver and hammer trick. I didn't have to! I got the screw driver and hammer lined up and it just sort of fell into place. I couldn't believe it. It looks like a lot of people shave the tool down because this is a common problem.
- Many people recommended the bearing race driver tool from AutoZone (https://www.autozone.com/loan-a-too...m-bearing-race-and-seal-driver-set/391360_0_0) I found this to be utterly useless. There isn't enough room to actually hit the end with a hammer with any sort of force. I used a socket (either 1 1/8 or 1 1/16, I think).
- Removing the old axle seal was also a pain. The slide hammer loaner made quick work of that: https://www.autozone.com/loan-a-too...-slide-hammer-puller-attachment-kit/69342_0_0 (Turn the hooks so that they face outward.)
- To install the new axle seal, a little grease on the outside edge was recommended. It went in easier than expected once i rented this set https://www.autozone.com/loan-a-too...3-pcs-ball-joint-u-joint-press-set/449947_0_0. One of the adapters fit perfectly around the outer edge of the seal (metal covered in rubber). Just be careful not to install it too deep.
