With the summer heat coming in I finally got around to cleaning my AC condenser coil, it was absolutely filthy. First time I've cleaned it since I've moved in (and who knows if PO cleaned them or not), if not it's an 18 year old system so it was overdue. Also vacuumed out the old leaves in the bottom of the housing. Going to pull the evaporator this weekend and clean that and change the filter as well. And now looking at these pictures, my house is due for a power wash
Took advantage of some cooler weather we had yesterday and got to work building up my shooting backstop. My dad came over for a few hours to help. Got all the posts set and two layers of ties lagged and rebarred together. Used 4x6x12 and some 3/8"x8" galvanized anchor bolts. Probably overkill but I only want to build it once and not have to mess with it leaning or falling over. I plan to do 10 ties high (70"), but I'll leave the 4x6s long in case I want to build it higher. My neighbor two doors down has some left over fill dirt he needs to get rid of anyhow so he said I can have it for free, a short drive over with the kubota and I'll be set! Hoping to get the rest of the ties set this weekend if it's not too hot and it isn't raining.
