night_angel
Did AllPro ever respond to your Thomas?
I have no response yet...I still waiting...!
Right there! Also, do the Murphy cup! Take a 3" ABS plumbing cap ($3-
$4US at Home Improvement store) cut it down to about 1" tall and then put a bunch of dry graphite on the top of the uniball - could even spay some of the Teflon spay in there first - then seal the uniball up by RTVing the cup to the top of the UCA. It is not a cure all and it won't protect the underside, but gravity will be your friend there! You could always thread a little screw on the top of it to allow you to put more in when you need to. - Good Luck!!!
I've been running the Total Chaos LT kit for almost a decade on my truck. When I bought my set the guys there told me it was the first kit sold east of Arizona. I do get some squeaking from the uni balls every now and then. Mainly after a good rinse down like you had said. All I've ever used is a few drops of motor oil monthly or if they start to squeak. Mine have over 40k miles on them and not much of that very easy and really don't have any signs of wear. If your All-Pro set is wearing out that fast, I'd have to suggest to swap over to Total Chaos or Camburg/ICON (no experience with them though). You get what you pay for on suspension products and buying a pair of cheap-o's expecting failure doesn't sound like a good plan. UCA failure goes real bad real fast and never happens at a time when its "safe". Check gun shops and lock-smiths for graphite lube, but most hardware stores carry it around here. I've never thought of using it to lube them up and I have a tube laying around, may do that next time to test it out.
I'm no fan of All Pro but I will say they use good uniballs from what I have read.
The ones in my A/P UCAs failed in about 12 months.
Were they FK's?
*prays they aren't*
Don't know - they're in storage - I will check. I wouldn't get nervous. Just treat them well and see what happens.
My TC's with chrome balls after about 9 months / 10,000 miles
Those things look like they were rode hard and put up wet their whole life, did they ever see lubrication or a cleaning? Not trying to be an asshole or get on your ass, like I said, a lil dab of motor oil occasionally and mine are looking like this after 40k+ miles and they were installed in May of 2006.
I'll have to pop them off some day to roll them and see what the race area looks like but everything you can see from full compression is still pristine. I do try and take real good care of them and wash my truck regularly and lube them. This was one of the biggest single investments I've done to my truck and I do what I can to make it last.
So, definitely I'll have to buy some new Unibol and replace them ... ALL-PRO did not
answer me...
Sadly I placed an order with AP last night......couldn't find any other vendor who has what I want and I do not have the equipment/skills to produce what I need.
What were you looking for?
Yeah, I'll probably just order some hardened, round bend, u bolts from an online hardware store and make a top plate in the shop real quick.Yeah 3" fit, they are snug but its all good. I think I got mine from front range for pretty Cheep and then just went to vatozone and bought a Cheep 3@block lift for longer ubolts because of my Dakars.
