Well I finally got around to changing the LPOP and front crank seal, everything fired back up ok I'll keep my fingers crossed no leaks.
Crank bolt removed, keyway was RTV'd from the factory so luckily that didn't pop out when I pulled the HB.
HB removed, old oil pump full of wonderful dirty diesel oil
Old oil pump removed and sealing surface cleaned up
While I was at it I just went ahead and put on a new HB, it also came with the wear ring pressed on which was an added bonus
Old LPOP and HB
New Melling M208 oil pump with seal that comes pressed in. Melling is supposedly higher flow than stock and is a 10 tooth pump vs. stock which is 14.
New pump torqued down on the timing cover and seal lip greased
HB pressed on and torqued to 212 ft. lbs, that was fun. 6 speed makes easy work to keep the crankshaft locked
Everything reassembled minus the fan and shroud
The cheap ass fan clutch rental tool bent on me so I borrowed my buddies 1-7/8" wrench to tighten the fan on the water pump
I also picked up a Tonneau cover from FB market place for half price of new, a Truxedo Lo Pro. I'm digging the extra dry storage and it rolls up easy and doesn't hinder any bed storage if I need to have the bed open.
Long day, and now time for a shower and some much needed rest
