Got a link for that exterior light?
Insulators came out today and spray foamed the attic.
While they were doing that, I sistered this floor joist. I had been putting it off and finally got around to it since I won't be able to install once it's been spray foamed. This is an approved repair by the structural engineer (I designed the repair & spec'd the fasteners and he signed off on it).
I run a bunch of Smurf tube for any place I am or might put a TV for future cabling. This was my first time installing Smurf tube and it's pretty sweet. I drilled a 1" hole in the blue electrical box and the 3/4" male ENT fitting just screwed right in. No need to use a locking washer on the inside because it's such a tight fit.
I got the flood light installed for the garage. I installed this same light at my mom's in ~2018 or earlier and it puts off just enough light to see but not be overbearing. I also angled this light slightly more towards the garage so it shines on my garage and not the neighbor.
Gebosun 35W AC Powered Street Light & Flood Light, with Optic Sensor, Dusk to Dawn, 5,400 Lumen, 6,000K, IP65 Waterproof, Wall-Mounted & Pole-Mounted https://a.co/d/2vAkUcUGot a link for that exterior light?
TV is on order and should be here on the 14th.
At this tiny house, I only have 2 hose bibs, I bought a set of these instead of crappy foam covers.
Link? Those are nice.
My pool has a bunch of ice on the water falls and stuff but nothing else.
