Tools!
I think the Milwaukee M18 batteries are crap and not true lithium, They are too heavy and crap out too soon. When does the class action lawsuit begin?
Looks like PF already covered this, oem is way to go, but he said Labtech was the runner up.
I have not noticed any degradation in performance with the smaller china batteries. But they do feel cheaper.
I’d recommend putting your battery chargers on a timer. A farmer near my parents place had a machine shed burn down due to a Milwaukee charger causing a fire. Had about $3M worth of farm equipment in it along with some custom motorcycles and old muscle cars. Dad said the tools that “survived” the fire, you could throw a socket on the ground and it would shatter.
Never had a problem with my Milwaukee batteries until they got to around 5 years of age. I will give you $3.50 for all that Milwaukee junk so you can go get DeWhat tools.
I only charge them when they need it and typically don't leave on the charger for any extended time.
Mine get used quite a bit here. Are you even home enough to use your tools?
I am guilty of putting a battery on the charger and forgetting about it until I need it. The timer is a bonus for me.
My gripe with M18 design is how bad the batteries shake on the tool due to how it clips in. They also go empty pretty quick because Milwaukee is getting every ounce of juice outta the battery so the tools make max power.
When building the deer blinds at Jason's ranch, we went through four or five M18 batteries a day on various tools (impact, drill, nail guns, sawzall & saw), versus my 20V stuff (impacts, saw, & sawzall) lasted usually to the end of the day. My M12 batteries made it to lunch.
But if I had to start all over again, it would be Milwaukee M12 tools and Makita's new 40V line. My theory is to use as small a tool as I can for daily stuff (driving screws, drilling holes, etc...) and as large a battery as I can get for heavy power draw tools (table saw, lighting, worm-drive saw, HEPA shop vacuum, etc...).
Yeah I have makita tools from 2013, the batteries are about the same as the18month old milwaukee batteries.
I paid good money for these red lithium m18 batteries and I feel like I got ripped off.
I might buy new batts, swap the guts and warranty the new ones, it's BS
Reach out to customer service first. They may warranty them if you tell them they are draining faster than you'd expect them too
The latches broke so I ordered some metal ones for it. This will be the last time I fix this thing before I finally bite the bullet and get another Pelican cooler on wheels.
Swapped out the speed feed head on my weed eater for a new one. I get a mowing season out of one of these heads.
Added more case lube to the weed eaters head. Thankfully, the grease inside still looked fresh.
Did an oil change on my Honda lawn mower and put in a new air filter. I'll sharpen the blades later this week.
The bearing went out on my craftsman belt sander so I've got to take that apart in a couple of months when I have time and fix it. Damn near pissed myself when the bearing went while I was grinding down a screw for an MLOK attachment lol Somehow the belt barely stayed on the roller.
Ordered one of these to try out. I'm tired of spilling gas when filling small equipment. I figured it'd also be helpful if my wife ever needed to fill up a generator or something and I'm not at home. Hopefully it works out.
I have one of those electric pumps. It works good.
I use the cheap two D cell pump from harbor fright to fill up my tractor, think it’s $8. Makes it easy instead of holding 5 gallons of diesel up above the bonnet.
My mom uses something very similar to that. She has a few at the farm to fill the tractor and mules. Then 1 on the dock at their house to fill up the boat.
I picked these up today, actually got two sets. One for my toolbox in the shop and one set for my range bag. I primarily bought them for sight/trigger adjustments on a few of my Henrys but figure they might come in handy in the garage on those super tiny allen keys. I had a craftsman set but they are all in a ziplock bag and it sucks to dump the whole set out every time I need to find the right one to use. Wiha is also made in America or maybe Germany, but definitely not Chyna
