What have you done to someone else's ride lately?
That wear pattern is not from lack of rotation. He’s got other issues.
X2 on Blake's comment. Guess it's a jeep thing, and I wouldn't understand
Those wear marks are definitely from a worn out suspension/steering. Used to get the same thing on my first gen when my tie rod ends would fuck up. But pretty much any worn out bushings/suspension could cause it.
Interesting. I hadn't really thought about checking anything else. I know the outer tread will feather with time. I just figured he let it go so long that the inner blocks started to feather as well.
Not sure it's worth your time and efforts to help that neighbor out for what was offered.
No, it's really not. I'm not about to start chasing down issues on his vehicle. I just thought the wear pattern was interesting as I've never seen one that bad before....then again, I don't know anyone who doesn't rotate tires. We've been neighbors for 4 years and those are the same tires he had when we moved in, so they were on the front for at least that long.
Swapped the battery out in my mom's X5. Apparently these batteries are on back order so I was lucky to find a dealer on the other side of town that had one in stock. The OEM battery lasted 7 years so I can't complain about $260 for a new OEM battery.
This battery is a monster.
Most importantly. Did you reset the cpu for the new battery?
Pin op Truth
Guess I'll do that when I get home. Car said it was recalibrating itself and to "drive carefully" until it recalibrated all the safety modules lol
Pin op Truth
The newer cars apply move voltage/amps to the battery as the battery ages which prolongs the life of the battery. If a reset is not performed, it will continue to charge at a higher rate thinking the old battery still remains.
Good to know! I'll reset it when I get home.
Showed my son how to change his oil. Then he did the tie rod ends and replaced the steer wheel controls for the radio. Next project will be the plugs/coil packs and brakes.
We dragged Jason's old bronco out of the brush and got her running in an hour and a half. We cleaned it out and Andy rewired a bunch of stuff. We went into town to for a new battery, fuel filter and ran a new gas line to the motor from the gas tank. There had to be at least 20 pounds of rat shit on the bronco. It was insane.
Then we drove it around the ranch and got a doe kill within the first mile of driving it!
Cleaning it up!
Driving around.
Unfortunately the bronco burned about 5 gallons of fuel in 7 miles. It needs a new water pump, fan and a belt. Jason got all that on order and already got off the water pump.
Looks like it was in a flood!
